M8 Bobbed Gas Tank Raw - V-Twin 38-1349 - Milwaukee-Eight Softail 2018+
Bobbed gas tank is one piece and has a fuel apacity of 4.8 gallons featuring a raw finish for M8 models. Frisco mount higher than stock original tank.
Features bolt on installation with original hardware. Check the tank for flaws or fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. The petcock fitting should be masked or plugged during painting for easy installation of the petcock. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Length: 55cm
- Width: 18cm
- height: 34cm
| 2018-UP | FLST |
| 2018-UP | FXST |
