Harley Big Twin Lower Front Mount Tie Rod Ball Joint - V-Twin 2690-1 - OEM 87254-34
Sidecar tie rod that links the sidecar body to the motorcycle frame, a direct replacement for a bent, worn, or stripped stock part. Fits 1924-1984 Harley Big Twin, J Model, Flathead, Knucklehead, Panhead, and Shovelhead models.
OEM #: 87254-34
Lower front mount tie rod ball joint.
The ball diameter is 1.259 inch the step down from that is.940 inch the center is 1.007 inch the step down from the center is.857 inch and the end is 1.012 inch. *NOTE: Ball joint only without gland or hex nut.
- Length: 3.557 inches
| 1936-1952 | EL |
| 1941-1984 | FL |
| 1924-1929 | JD |
| 1938-1948 | UL |
| 1930-1933 | VL |
