Harley Big Twin Linkert Carburetor Bowl Lock Nut with Drain Zinc - V-Twin 35-0368
Zinc carburetor float bowl part, a direct replacement for a cracked, stripped, or leaking stock bowl component. Fits 1936-1965 Harley Flathead, Knucklehead, and Panhead models.
Linkert carburetor bowl lock nut and drain is zinc plated and is for use with all brass Linkert bowls. The nut and drain allows water to drain without removing the bowl.
This special float bowl nut with a 1/4 inch allen drain screw allows the draining of condensation and water that settles in the bowl. We've paired this with a stainless steel nozzle spring and crush gasket.
| 1936-1952 | EL |
| 1941-1965 | FL |
| 1937-1957 | G |
| 1937-1952 | W |
