Harley Big Twin Linkert Carburetor Bowl Lock Nut with Drain - V-Twin 35-0374 - OEM 27375-29
Carburetor float bowl part, a direct replacement for a cracked, stripped, or leaking stock bowl component. Fits 1936-1965 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 27375-29
Linkert carburetor bowl lock nut and drain is for use with all Linkert bowls. The nut and drain allows water to drain without removing the bowl.
This special float bowl nut with a 1/4 inch allen drain screw allows the draining of condensation and water that settles in the bowl.
| 1936-1952 | EL |
| 1941-1965 | FL |
| 1937-1957 | G |
| 1937-1952 | W |
