Harley Big Twin Lindby Custom Front Engine Bar - V-Twin 50-2064
Front engine bar that dresses up the frame rail and gives your legs a highway mounting point. Fits 1965-1975 Harley Panhead and Shovelhead models.
Front engine bar feature 1-1/8 inch tubing with built in O-rings on the footpeg area.
Front engine bar is constructed of a high strength steel and is precision bent and welded for a perfect fit. Bars are compatible with most stock exhaust system require removal of rear footpegs and floorboards. WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). It is not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Not recommended for use with extended forward controls or extended floorboards.
| 1965-1975 | FLH |
