Left Side UL Engine Case - V-Twin 10-0879 - OEM 24536-37
SKU 10-0879
Original price $619.99 - Original price $619.99
$619.99
6199 ENTRIES 🎟️
$619.99 - $619.99
$619.99
6199 ENTRIES 🎟️
OEM #: 24536-37, 410-37, 406-37
Side valve replacement left side engine case features a blank number boss. This case has the same oil passage for the outside sprocket shaft bearing as the original case.
NOTE: Left side case must be fitted to existing OE right side case. Cylinder base surfaces and motor mount surfaces must be milled to match before assembly. *NOTE: Requires hole to be drilled in the left case. Cast in the bushing after the case race has been pressed in. Install the race and then drill the hole. *NOTE: Left side cases accept standard case race.
  • Suggested to use with Sprocket Left Side Case Race Standard.
1937-1948 UL
