Harley Left Side Panhead Engine Case - V-Twin 10-0937
SKU 10-0937
Original price $619.99 - Original price $619.99
$619.99
6199 ENTRIES 🎟️
$619.99 - $619.99
$619.99
6199 ENTRIES 🎟️
Left side engine case features a blank number boss. Left hand case must be fit to existing right side case. Number boss is blank. Will accept Timken roller bearing assembly not included. Cylinder dock height must be machined to match to original right side case experience reqired. Not a bolt on installation. Cylinder base studs breather tube bearing assembly and drain plug all must be purchased separately. Case set required line lapping of the main case races. Order case race available separately. Fits 1955-1964 Harley Panhead models.
  • Suggested to use with Replica Bare Engine Case Set.
  • Suggested to use with Special Sprocket Shaft Spacer.
  • Suggested to use with Left Engine Seal.
1955-1964 FL
