LED Digital Speedometer and Tachometer Assembly - V-Twin 39-0609
SKU 39-0609
$219.99
2199 ENTRIES 🎟️
$219.99 - $219.99
$219.99
2199 ENTRIES 🎟️
Speedometer and tachometer combination unit has a 5 inch LED face and is programmable to 1:1 2:1 or 2240:60 ratios with cable drive for speedometer.
Features red engine/oil blue high beam green neutral and yellow turn signal lights. Includes connection to accept 12mm or 5/8 inch with brass nut cable fittings. Tachometer is impulse type with one wire to the ignition coil.
