King 3.2 Gallon Gas Tank - Wyatt Gatling 38-0274 LIN
SKU 38-0274
$259.99
2599 ENTRIES 🎟️
$259.99 - $259.99
$259.99
2599 ENTRIES 🎟️
Wyatt Gatling #: 38-0274 LIN
King gas tank is carburetor type with a left side petcock. Tank has a fuel capacity of 3.2 gallons.
*NOTE: Has external threads for the petcock. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Check the petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged for easy installation of petcock. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Center to Center: 14-5/8 inches
  • Front Width: 2-1/4 inches
  • Center Width: 2-5/8 inches
  • Rear Width: 1-3/8 inches
  • Suggested to use with Kreem Gas Tank Combo Kit.
