Harley K&N Replacement Air Filter - K&N HD-9608 - OEM 29161-08 - Twin Cam Dyna 2008-2017
K&N replacement air filter is pre-oiled and ready to. The filter is designed to provide increased airflow which will result in increased horsepower and torque. It also has a pleated design and zinc coated plates to assure years of filtration without corrosion. This replacement air filter will fit your OE air filter assembly. It requires no fuel management modifications and is a washable type. Fits 2008-2017 Harley Dyna models.
K&N #: HD-9608 · OEM #: 29161-08
- We recommend checking the air filter every 30 000 miles but most street conditions the filter does not require cleaning until 50 000 miles of continuous.
| 2008-2017 | FXD |
