Illuminator Turn Signal Module - Namz ILL-01
by Namz
SKU 33-0713
$119.99
$119.99 - $119.99
$119.99
Namz #: ILL-01
This hard wire type illuminator module allows turn signals to be used for running and brake lights without losing their turn signal function.
Turn signal module has a built in load equalizer III works with your stock OEM turn signals with stock 1156 single function Incandescent bulbs custom Incandescent small turn signals Halogen and LEDs runs mixed front and rear. Also features optimized modulation technology for distinct intensity difference from run to turn to brake modes and easy to follow instructions and connector plugs included. Compatible with security systems. For 1973-1984 XL FX and FL models. Can also be used on motorcycles with modified wiring or without factory plugs. **NOTE: For applications without self cancelling turn signals.
1973-1984 FL
1979-1985 FLT
1973-1984 FX
1982-1985 FXR
1973-1998 XL
