Harley Ignition Switch Converter Module - Namz NCB-ISCM
Ignition switch converter module allows the removal of OEM ignition switch while using any custom switch in it's place. Module converts the momentary switch into a hi/low latching and on/off latching for a run switch. Simply add fused power a ground wire and connect your momentary switches for the latching functions you need. Universal fit for most Harley applications.
Namz #: NCB-ISCM
