Harley Big Twin Ignition Points Set - Volt Tech A-32658-30 - OEM 32658-30
SKU 32-0120
299 ENTRIES 🎟️
299 ENTRIES 🎟️
Set of electrical contacts that switch the coil on and off at the proper time. The mechanical action of the distributor shaft lobes pushes the points open and closed. For use with braided points wire. It is suggested to double up the contact wire to take up the extra slack fold wire over on itself and press down into the fiber channel to avoid a short. Use flathead screws to mount points as supplied. *NOTE: The spring is.583 inch -.585 inch long with a.230 inch outer diameter and.165 inch inner diameter. Fits 1930-1947 Harley Flathead and Knucklehead models.
Volt Tech #: A-32658-30 · OEM #: 32658-30, 1569-30A
1936-1947 EL
1941-1947 FL
1930-1935 VL
1936-1947 W
