Harley Ignition Coil Mini Dual Output Towers - Dyna Tek DC6-5
Dyna Twin Fire ignition coil is designed to work with Dyna 2000 H-DI ignition modules. Twin fire coils are slightly larger than stock coils and fit the stock mounting bracket. Twin fire coils can be used with any electric advance ignition system that incorporates dwell control except Dyna DS6-2 or similar type ignitions. Twin fire coils feature miniature dual output towers 3 ohms replaces Dyna DC6-4. **NOTE:Check the coil primary resistance requirements from the manufacturers of the ignition being used. Universal fit for most Harley applications.
Dyna Tek #: DC6-5
| 0 | Special |
