Harley Panhead Hydraulic Rear Brake Shoe Springs - V-Twin 13-9260
Drum brake shoe spring, a clean swap for a weak, rusted, or broken stock spring that's keeping the shoes from seating or releasing properly. Fits 1960-1962 Harley Panhead models.
Rear brake shoe springs for hydraulic brake.
Set of two. Upper brake shoe spring installation requires brake shoe cams to be turned inward. The short hook end of the spring must be placed into the slotted hole of the front shoe from underneath the long end is placed into the outer round hole of the rear shoe from above.
- Long Spring Length: 4-1/2 inches
- Short Spring Length: 2 inches
| 1960-1962 | FL |
