Harley Big Twin Handlebar Throttle Spark Control Spiral - V-Twin 49-1578
SKU 49-1578
649 ENTRIES 🎟️
649 ENTRIES 🎟️
Chrome Spring Fork handlebar throttle spiral is pull type. To activate the linkage on the Keihin Bendix carburetor you are required to do the pulling and the linkage will open to the throttle. *NOTE: Use the inchpull inch type handbar spirals to use braided pull type cables. Use the same outer cable as required for each type of handlebar. Carburetor return requires spring loading. Fits 1935-1952 Harley Flathead, Knucklehead, and Panhead models.
1936-1940 EL
1941-1948 FL
1935-1952 G
1937-1948 UL
1935-1936 VL
1935-1952 WL
