H-3 Battery Box Kit - V-Twin 53-0932 - Sportster 1952-1964
SKU 53-0932
$129.99
1299 ENTRIES 🎟️
$129.99 - $129.99
$129.99
1299 ENTRIES 🎟️
H-3 battery box kit is black painted with chrome top. Set will hold a 6 or 12 volt sealed battery. Kit includes chrome top and black box.
Hold down rods or springs may be used to secure top box (not included). Box has slot for wire exit. Isolate battery with foam or rubber padding are not supplied. Use 1/4 x 20 inch bolts to attach cover to mount base on your custom frame. Base can be fabricated from 1/8 inch steel sheet. Batteries 12v and 6v are available to fit into box shimming is required for a proper fit.
  • Suggested to use with Anti Gravity 12 Volt 16 Cell Battery
  • Suggested to use with 12 Volt 5 AH Rechargeable Sealed Battery
  • Suggested to use with 6 Volt 14 Amp Rechargeable Sealed Battery
  • Suggested to use with Universal 6 Volt Battery
1952-1956 K
1957-1964 XLH
