Harley Front Wheel Bearing for 26 Custom Wheels - V-Twin 44-0903
Replacement wheel bearing for 26 inch wheels with a 25mm axle. For use on ABS and non ABS wheels. ABS models require one ABS bearing and one non ABS bearing. Designed for bikes with larger than stock diameter wheels. Bearings for larger than stock diameter wheels have a greater reinforced magnetic area that will not set off any engine codes after proper installation. Universal fit for most Harley applications.
- Outer Diameter: 52mm
- Thickness: 18mm
