Harley Flathead Front or Rear Wheel Hub Parkerized - V-Twin 45-0981
SKU 45-0981
$159.99
1599 ENTRIES 🎟️
$159.99 - $159.99
$159.99
1599 ENTRIES 🎟️
Parkerized front or rear wheel hub is for use with 18 inch and 19 inch rims. Sphere is 12 tooth and 10mm deep with a total length of 56mm. The sphere starts at 7.7mm from the edge. Parts required for internal assembly are not included. *NOTE: Must order and separately. Fits 1930-1936 Harley Flathead models.
  • Suggested to use with VL Retro Wheel Bearing Kit.
  • Suggested to use with VL Hub Lock Nut Set.
  • Suggested to use with VL Hub Washer Set.
1930-1936 VL
