Harley Flathead Front or Rear Wheel Hub Nickel Plated - V-Twin 45-0985
SKU 45-0985
$189.99
$189.99
$189.99
1899 ENTRIES 🎟️
$189.99
$189.99
$189.99
1899 ENTRIES 🎟️
Nickel plated front or rear wheel hub is for use with 18 inch and 19 inch rims. Sphere is 12 tooth and 10mm deep with a total length of 56mm. The sphere starts at 7.7mm from the edge. Parts required for internal assembly are not included. *NOTE: Must order and separately. Fits 1930-1936 Harley Flathead models.
- Suggested to use with VL Retro Wheel Bearing Kit
- Suggested to use with VL Hub Lock Nut Set
- Suggested to use with VL Hub Washer Set
| 1930-1936 | VL |
