Harley Front or Rear Axle Spacer 3/4 Inner Diameter - V-Twin 44-0670
Axle spacer is constructed of stainless steel and features a polished finish. Can be used for front or rear applications.
Must be cut to desired length.
- Overall Length: 6 inches
- Inner Diameter: 3/4 inches
- Outer Diameter: 1-1/8 inches
