Harley Front or Rear Axle Spacer 1 Inner Diameter - V-Twin 44-0753
SKU 44-0753
$54.99
549 ENTRIES 🎟️
$54.99 - $54.99
$54.99
549 ENTRIES 🎟️
Axle spacer for the front or rear is constructed of stainless steel. It has an overall length of 6 inch 1 inch inner diameter and 1-3/8 inch outer diameter.
Must be cut to desired length.
  • Overall Length: 6 inches
  • Inner Diameter: 1 inches
  • Outer Diameter: 1-3/8 inches
