Harley Big Twin Front Lower Side Car Clamp Set - V-Twin 49-1989 - OEM 87205-58
Sidecar clamp that secures the sidecar mount to the frame tube, a direct replacement for a worn, cracked, or missing stock clamp. Fits 1958-1999 Harley Big Twin, Panhead, and Shovelhead models.
OEM #: 87205-58
Side Valve lower front bracket set is the clamp on style.
U-clamp not included. Requires four U-Bolts for mouting. *NOTE: Order U-Bolts separately.
- Required to use with Mousetrap Clutch U-Bolts.
| 1958-1999 | FL |
