Harley Front Fender Raw Steel - Wyatt Gatling 090531
Raw front fender, a direct replacement for a dented, rusted, or missing stock fender. Universal fit for most Harley fender applications.
Wyatt Gatling #: 090531
Wyatt front fender is 2mm thick raw steel laser cut from full piece blanks.
The outer diameter of the bracket is 8 inch. Inside width of the fender is 4-7/8 inch. Fender has a 140° radius and not drilled. For use on 21 inch wheels. Spacers are required if using this fender on 41mm forks. We suggest pre fitting the fender prior to painting. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Degree: 140
- Outer Diameter: 8 inches
- Inside Width of Dia.: 4-7/8 inches
- Length: 24-3/4 inches
- Inner Width for Tire: 5-15/16 inches
