Harley Front Fender Gunfire Raw Steel - Wyatt Gatling 090502
SKU 50-0390
$74.99
749 ENTRIES 🎟️
$74.99 - $74.99
$74.99
749 ENTRIES 🎟️
Raw front fender, a direct replacement for a dented, rusted, or missing stock fender. Universal fit for most Harley fender applications.
Wyatt Gatling #: 090502
Wyatt Gatling front fender is constructed from 1.5mm raw steel.
Fender is designed for custom applications no mounting holes are drilled. Fender has 180° coverage with built in 4-1/8 inch wide brackets. Fender is 4-1/4 inch wide at the ends and gradually widens to 7-3/8 inch at the fender mounts. The fender measures 24 inch from front to back. Spacers are required for use on 41mm glide forks with 21 inch wheels. We suggest pre-fitting fender prior to painting. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
