Harley Front Axle Zinc Plated - V-Twin 44-0256 - Big Twin 0+
Zinc front axle, a direct OEM-spec replacement for a worn, bent, or rusted stock axle that keeps the wheel running true. Universal fit, replaces the stock axle on most Harley applications.
This axle has a 9-3/4 inch bearing surface length and can be used to replace a worn out or damaged axle that are used with our fork slider sets.
- Bearing Surface: 9-3/4 inches
- Surface w/o Thread: 9-1/2 inches
- Overall Length:
- Outer Diameter: 3/4 inches
- Threads per Inch: 20
- Suggested to use with fork assembly
| 0 | Replacement |
