Harley Big Twin Front Axle Spacer 5/8 Inner Diameter - V-Twin 44-0111 - OEM 43884-36
Axle spacer kit for the front wheel, setting correct hub spacing and including the washers and nut needed for a clean install. Fits 1936-1948 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 43884-36, 4180-36
Parkerized Spring Fork front axle spacer. Spacer measures 5/8 inch inner diameter x 1-1/16 inch outer diameter x 1-5/8 inch long.
- Overall Length: 1-5/8 inches
- Inner Diameter: 5/8 inches
- Outer Diameter: 1-1/16 inches
| 1936-1940 | EL |
| 1941-1948 | FL |
| 1937-1948 | UL |
