Front 16 x 3.5" Duro 36 Fat Spoke Matte Black Wheel - V-Twin 52-0031 - Twin Cam Touring 2000-2007
Front 16 inch x 3.5 inch Duro 36 Fat Spoke wheel features a matte black finish and 1 inch bearings. Accepts dual 11 inch rotors.
Wheel bearing adapter sleeve sets available separately. *NOTE: The rim width is 109mm from flange to flange and 89mm from bead to bead. *NOTE: Wheels will bolt on to models that are listed. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Please read the following tech notes carefully before buying to avoid mistakes: 1. The wheel fits Harley bikes with 1inch axle.
- Suggested to use with Cast Wheel Spacer Set Zinc Plated
| 2000-2007 | FLT |
