Forward Brake Control Kit Hydraulic - V-Twin 22-0506
Kit is equipped for models powered by Shovelhead or Evolution engines and with hydraulic brake system.
Includes brake pedal pedal stop plate brake line support bracket a Wagner style master cylinder master cylinder spacer brake pedal plunger clevis p ns clutch finger shaft washer. Footboards can be fitted to this kit.
- Suggested to use with front line stainless steel Suggested to use with rear line stainless steel Suggested to use with brake tee
| 1970-1978 | FL |
