Harley Big Twin Flywheel Thrust Washer Set - V-Twin 10-1153 - OEM 24100-17
SKU 10-1153
599 ENTRIES 🎟️
$59.99 - $59.99
599 ENTRIES 🎟️
Crank pin flywheel inside washer set contains two more washers than the original set one thicker and one thinner than stock. The 11-piece set contains one each of the following widths:.060.066.070.074.078.082.086.090.094.098 and.102. Fits 1930-1954 Harley Flathead, Knucklehead, and Panhead models.
OEM #: 24100-17, 358-17A
  • Inner Diameter: 1-1/4 inches
1936-1940 EL
1941-1954 FL
1937-1948 UL
1930-1934 VL
