Harley Flush Mount Front Axle - V-Twin 44-0891 - Big Twin 0+
SKU 44-0891
449 ENTRIES 🎟️
449 ENTRIES 🎟️
Flush-mount front axle that sits smooth with the fork or frame instead of sticking out, a direct OEM-spec replacement for a worn, bent, or rusted stock axle. Universal fit, replaces the stock axle on most Harley applications.
Flush mount front axle has a 9-1/4 inch bearing surface length and fits 41mm billet forks.
Accepts flat head allen screws of 1/2 inch diameter x 20 threads per inch to be ordered separately requires quantity 2.
  • Bearing Surface: 9-1/4 inches
  • Surface w/o Thread:
  • Overall Length: 10-3/4 inches
  • Outer Diameter: 3/4 inches
  • Threads per Inch:
  • Suggested to use with Allen Flat Head Screw.
  • Suggested to use with Fork Assembly with Chrome Sliders.
0 Replacement
