Flatside Shovelhead 74 Long Block - V-Twin 10-2002
SKU 10-2002
Original price $6,989.99 - Original price $6,989.99
$6,989.99
69899 ENTRIES 🎟️
$6,989.99 - $6,989.99
$6,989.99
69899 ENTRIES 🎟️
Assembled and tested for oil pressure.
Flatside shovelhead long block is 74 inch cubic inch displacement featuring Sifton oil pump/breather assembly stock stroke flywheel Timken bearing stock lift FLH cam with a matched pinion and cam gear and a Torrington bearing. Cylinders are stock style with 8.5:1 standard compression which include cast pistons and rings. Includes clamp style automatic advance distributor. Assembly is supplied with a natural finish Flatside 1966-1969 stock style cam cover chrome lifter blocks which are fitted with tappets and pushrods. *NOTE: Rocker boxes are polished. Order manifold carburetor and 2 brush generator separately. Entire unit is pre run and factory tested for oil pressure. Manufacturer's Statement of Origin is supplied. *NOTE: Delivered by truck only. Long block does not include carburetor.
1958-1964 FL
