Harley Big Twin Fat Bob Ignition Switch Component Kit - Volt Tech 72584E - OEM 71501-36
SKU 32-1271
399 ENTRIES 🎟️
399 ENTRIES 🎟️
Fat Bob ignition component kit for 5-post switches will replace internals on stock original or aftermarket switch. Switch base included.Order switch cover and lock keyhole cover separately. Or reuse your existing 5 post key switch cover and base for accurate restoration! The top cover supplied has a smaller hole to accommodate the key switch provided. Restorer may decide not to use the switch for cosmetic reasons. Will retro fit a stock switch housing and switch mount stand. Switch barrel is slightley smaller in diameter 1/16 inch less. All parts except switch barrel will interchange cover. Fits 1936-1967 Harley Flathead, Knucklehead, Panhead, and Shovelhead models.
Volt Tech #: 72584E · OEM #: 71501-36
  • Open: 1.9 inches
  • Closed: 1.75 inches
1936-1952 EL
1941-1967 FL
1936-1963 G
1936-1952 W
