Fat Bob Gas Tank Kit 3.5 Gallon - V-Twin 38-0644
SKU 38-0644
Original price $569.99 - Original price $569.99
$569.99
5699 ENTRIES 🎟️
$569.99 - $569.99
$569.99
5699 ENTRIES 🎟️
Bobbed gas tank kit includes a 3.5 gallon capacity gas tank set with emblem mounts welded in place. Kit includes 1955 - 1956 emblems with screws gas cap set shifter lever with ball 4 speed shifter gate and a zinc gas tank mount kit.
Kit features provisions for reserve shut off rod which is not included. For hand shift applications and will accept 3/8 inch NPT petcock with male threads not included. Opening is on the left side forward on the tank. *NOTE: Check the shut off opening making sure the shut off valve can be easily installed. The shut off fitting should be masked or plugged during painting for easy installation of the shut off valve. Check the tank for flaws and fit before painting. Do not grind or sand seams or joi nts. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. All tanks or tank sets require hand fitting to give correct alignment for dash and fuel line fitment. Dash will have to be shimmed when installed or achieve correct height. Tank mount bolt kit not included order separately. t in higher shipping costs.
  • *NOTE: UPS may consider this part as packaged inchoversizeinch for shipment as compared to the actual weight which will result in higher shipping costs.
1955-1956 FL
