Fat Bob 3.5 Gallon Gas Tank Set - Wyatt Gatling 011381
SKU 38-0119
$329.99
3299 ENTRIES 🎟️
$329.99 - $329.99
$329.99
3299 ENTRIES 🎟️
Wyatt Gatling #: 011381
Fat Bob gas tank has a fuel capacity of 3.5 gallons.
Tank features provisions to accept two early vented gas caps reserve shut-off rod and two or three light dash. It also features shifter gate mount holes. Order shifter gate and mounting hardware separately. Tank may require fuel rod alignment before installation of shut-off assembly. Shut off fitting should be masked or plugged during painting for easy installation of shut off valve. Carefully check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal in order to help stop leaks and prevent corrosion. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 18-1/4 inches
  • Bottom Length: 17-3/4 inches
  • Rear Height: 1-1/4 inches
  • Front Height: 8 inches
  • Front Tunnel Height: 8-3/4 inches
  • Rear Tunnel Height: 1-1/2 inches
  • Suggested to use Kreem gas tank combo kit
  • Suggested to use shift gate for 4-speed transmissions.
  • Suggested to use shift gate for 3-speed transmissions.
1948-1965 FL
