Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0796
SKU 38-0796
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
Fat Bob gas tank set features provisions to accept early caps reserve shut off rod and two or three light dash. Does not have a shift gate provision or tank emblem mounts. For foot shift models.
Tank may require fuel rod alignment before installation of shut off assembly. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal in order to help stop leaks and prevent corrosion. Check the shut off opening making sure the shut off valve can be easily installed. The shut off opening should be masked or plugged during painting for easy installation of the shut off valve. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *NOTE: Order emblem mount separately. Dash panel mounts to cover plate which includes fuel pump assembly on *Notethese thanks.sider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 19 inches
  • Bottom Length: 18-1/2 inches
  • Rear Height: 1-1/2 inches
  • Front Height: 8-3/4 inches
  • Suggested to use with Kreem Gas Tank Combo Kit.
  • Suggested to use with Replica Eaton Vented Gas Cap Set.
1948-1965 FL
