Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0787
SKU 38-0787
$229.99
2299 ENTRIES 🎟️
$229.99 - $229.99
$229.99
2299 ENTRIES 🎟️
Fat Bob gas tank set comes without reserve shut off rod and shift gate. Tank will only use the 1975-up type petcock with 22mm nut.
Gas tank set accepts ONE non vented cap and one vented cap. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal in order to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting on left side accepts 22mm nut type petcock. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 18-3/4 inches
  • Bottom Length: 18-1/4 inches
  • Width Rear: 5-3/4 inches
  • Width Front:
  • Rear Height: 1-1/2 inches
  • Front Height: 8-1/2 inches
  • Suggested to use with Stock Style Gas Cap Vented.
  • Suggested to use with Stock Style Gas Cap Non-Vented.
  • Features updated design to match OEM shape and contours.
1947-1985 FL
1971-1985 FX
