Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0183
Gas tank set accepts left side petcock with 3/8 inch NPT thread and has a fuel capacity of 3.5 gallons. The right side tank has 1/8 inch FNPT thread for fuel crossover tube. Tanks do not have emblem mounts.
Bobbed two piece gas tank set features handshift mounts. Accepts 1936-1946 type cateye dash panel. Check the tank for flaws and fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check petcock opening making sure the petcock can be easily installed. Petcock fitting should be masked or plugged during painting for easy installation of the petcock. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. Tanks accepts cateye style dashes only. *NOTE: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
- Top Length: 18-1/4 inches
- Bottom Length: 17-1/2 inches
- Rear Width: 2-1/2 inches
- Front Width: 4-3/4 inches
- Rear Height: 1-1/2 inches
- Front Height: 8 inches
- Front Tunnel Height:
- Rear Tunnel Height:
- Tunnel Length:
- Suggested to use Kreem gas tank combo kit.
- Suggested to use shift gate for 4-speed transmissions.
- Suggested to use shift gate for 3-speed transmissions.
| 1936-1939 | EL |
