Fat Bob 3.5 Gallon Gas Tank Set - V-Twin 38-0140
SKU 38-0140
$369.99
3699 ENTRIES 🎟️
$369.99 - $369.99
$369.99
3699 ENTRIES 🎟️
Gas tank is a two piece set with a fuel capacity of 3.5 gallons. Tanks do not include emblem mounts.
Tank features hand shifter mounts and shut off rod provisions. Order shut off rod and seat kit separately. Tank may require fuel rod alignment before installation of shut off assembly. Check the tank for flaws or fit before painting. Do not grind or sand the seams or joints. Clean the inside of the tank. It is suggested to pressure test and use a tank sealer. We suggest using Kreem gas tank combo kit to clean condition and seal to help stop leaks and prevent corrosion. Check shut off opening making sure the shut off valve can be easily installed. Shut off fitting should be masked or plugged during painting for easy installation of shut off valve. All tanks or tank sets will require hand fitting to give correct alignment for dash and fuel line fitment. Dash will also have to be shimmed when installed to achieve correct height. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
  • Top Length: 18-1/2 inches
  • Bottom Length: 17-1/2 inches
  • Rear Width: 2-1/4 inches
  • Front Width: 4-3/4 inches
  • Rear Height: 1-1/4 inches
  • Front Height: 7-1/2 inches
  • Front Tunnel Height:
  • Rear Tunnel Height:
  • Tunnel Length:
  • Suggested to use Kreem gas tank combo kit
  • Suggested to use shift gate for 4-speed transmissions.
  • Suggested to use shift gate for 3-speed transmissions.
1941-1946 FL
