Fat Bob 3.5 Gallon Gas Tank Set Raw - V-Twin 38-1942
SKU 38-1942
Original price $659.99 - Original price $659.99
$659.99
6599 ENTRIES 🎟️
$659.99 - $659.99
$659.99
6599 ENTRIES 🎟️
2025 New Production gas tank set is for use with UL models and features a raw finish. Gas tanks are 3-1/2 gallons for the right and left side.
Gas tank set features ribbed inside panels and a rounded indent on the left side of the tank. The reinforced ribs on the left side are pressed on for durability which was an upgraded feature for the 1941-1946 models. The right side does not have the indented ribs. Left side Gas tank features provision for a fuel shut off rod. Fuel shut off rod is not included. Tank fits 74 inch and 80 inch UL and ULH models only. *NOTE: Left side tank may require fuel rod alignment for fuel rod seat installation. Right side has welded fitting to accept fuel line crossover. *NOTE: Tank set accepts cateye or early skull type dash and base assemblies and early 1937-1946 type shifter gates.
  • Suggested to use with Gas Line.
  • Suggested to use with Crossover Gas Line.
  • Suggested to use with Fuel Petcock Shut-Off Rod Kit.
  • Suggested to use with #9660-1 Fuel Filter Strainer Kit.
1940-1946 U
