Factory Sample Front Engine Bar Chrome - V-Twin 51-2217 - OEM 49010-93 - Big Twin 1993-2005
OEM #: 49010-93
Chrome engine bar features 1-1/4 inch tubing and single top mount hole.
Includes U-bolts nuts and straight bolt. The width between bottom mount plates measures 12 inch outside to outside. The height from the top of the bottom mounts to the center of the top mount hole is 14-3/5 inch. WARNING: This engine/frame bar may provide limited leg and cosmetic vehicle protection under unique circumstances (fall over while stopped very low speed slide). They are not made nor intended to provide protection from bodily injury in a collision with an automobile or any other object. Factory sample cover are brand new pre-production parts but have imperfections in the finished surface. Check threaded and bearing holes for excess plating before installation. There are no physical defects such as cracks or holes there will be cosmetic imperfections only. Sample parts may show marks from installation test and fitment. *Note: UPS may consider this part as packaged inchoversize inch for shipment as compared to the actual weight which will result in higher shipping costs.
| 1993-2005 | FXDWG |
