Harley Panhead Engine Transmission Gasket Kit 49 Pieces - Gary Bang P400195850895 - OEM 17028-48
Complete 49 piece engine gasket kit includes all of the gaskets seals and o-rings necessary to rebuild Panhead engine. Kit includes head gaskets front and rear cylinder base gaskets Panhead rocker cover felt gaskets pushrod cover cork small gasket pushrod cover cork large gasket front and rear tappet gasket cam cover gasket oil pump gasket carburetor flange gasket generator case mount gasket distributor base gasket primary cover gasket derby cover gasket inspection plate gasket inner primary mount gasket valve guide gaskets and intake manifold o-rings. Fits 1948-1965 Harley Panhead models.
Gary Bang #: P400195850895 · OEM #: 17028-48, 51-48
| 1948-1965 | FL |
