Harley Big Twin Engine Pinion Shaft - Eastern A-24006-39 - OEM 24006-39
Precision ground for correct fitment. *NOTE: Check spline timing in relation to key way slot. Turn shaft so that the key way slot is at 12 o'clock on shaft. Oil hole and large spline should be at the 3 o'clock position before installing in flywheel for final assembly. Fits 1939-1953 Harley Knucklehead and Panhead models.
Eastern #: A-24006-39 · OEM #: 24006-39
| 1939-1940 | EL |
| 1941-1953 | FL |
