Harley Panhead Engine Gasket Kit - James JGI-17028-48 - OEM 17028-48
James engine gasket set include gaskets oil seals and o-rings necessary for a complete rebuild for Panhead engine. Kit includes head gaskets front and rear cylinder base gaskets Panhead rocker cover felt gaskets pushrod cover cork small gasket pushrod cover cork large gasket front and rear tappet gasket cam cover gasket oil pump gasket carburetor flange gasket generator case mount gasket distributor base gasket inner primary mount gasket valve guide gaskets and intake manifold o-rings. Order primary gaskets separately. *NOTE: Gaskets are teflon coated. Fits 1948-1965 Harley Panhead models.
James #: JGI-17028-48 · OEM #: 17028-48, 51-48
| 1948-1965 | FL |
