Harley Big Twin Engine Gasket Kit - Gary Bang P400195900898 - OEM 17029-79
SKU 15-0511
$99.99
999 ENTRIES 🎟️
$99.99 - $99.99
$99.99
999 ENTRIES 🎟️
Complete engine gasket kit includes all of the gaskets seals and o-rings necessary to rebuild Shovelhead 4-speed engine. Includes teflon head gasket front and rear cylinder base gasket rocker cover gaskets front and rear tappet gaskets cam cover and derby cover gaskets oil pump body paper gasket oil pump outer cover paper gasket oil pump case paper gasket oil pump cover paper gasket carburetor mount base gaskets air cleaner mount gasket point cover gasket starter hole gasket 1/32 inch primary cover gasket inspection plate gasket solenoid mount gasket copper dual exhaust gasket starter deflector gasket rocker arm o-rings oil cap o-ring v-2 middle pushrod o-rings large pushrod quad seal small flat pushrod o-rings clutch hub nut seal left engine seal manifold seals cam cover seal rocker line oiler seals starter shaft housing seal oil pump seal and inner primary o-ring. Fits 1978-1984 Harley Big Twin, FX (Super Glide), FXR, Touring, and Shovelhead models.
Gary Bang #: P400195900898 · OEM #: 17029-79
1978-1984 FL
1979-1983 FLT
1978-1984 FX
1982-1983 FXR
