Harley Knucklehead Engine Gasket Kit - Gary Bang P400195850894 - OEM 17028-36
Complete engine gasket kit includes all of the gaskets seals and o-rings necessary to rebuild Knucklehead engine. Kit includes pushrod cover cork seal tappet gasket carburetor flange gasket distributor base gasket oil pump mylar gasket oil pump gasket carburetor float bowl gasket copper head gasket rocker cover gasket kit cylinder base gasket generator gasket cam cover gasket valve guide gasket primary cover gasket derby cover gasket inspection plate gasket rocker arm oil seal and carburetor to manifold gasket. Fits 1941-1947 Harley Knucklehead models.
Gary Bang #: P400195850894 · OEM #: 17028-36, 51-36
| 1941-1947 | FL |
