Harley Engine 6° Taper Sprocket Shaft - V-Twin 10-1189
Special 6° tapered sprocket shaft is machine and hardened to factory specifications. Shaft is designed to fit late model type flywheels with a 6° taper. Shaft is not inchkeyed inch type taper. Nut not included. For use in S&S SE or SL flywheels and V-Twin V-Twin Replica 4.250 inch Stroke Flywheel Set or V-Twin Sifton 4.250 inch Stroke Flywheel Set. Universal fit for most Harley applications.
- Suggested to use with Replica 3.968inch Stroke Flywheel Set.
| 0 | Replacement |
