Electric Start Oil Tank Black - V-Twin 40-0618
Our black wrap-around 4-speed oil tank is for electric start models and has a four quart capacity. It features a built in battery box with a 7-5/8 inch width 4-1/8 inch depth and 5.5 inch height.
Accepts a 12 volt FXE type battery and braided or rubber lines. For use with stock rigid or swingarm frames. *NOTE: The battery has to be installed in the oil tank before mounting the oil tank. Tank require mount bracket on swingarm frames for installation.
- Fitting Threads: 3/8 inches -24
- Height with Bracket: 7-1/2 inches
- Height w/o Bracket: 5-5/8 inches
- Rear Height: 5 inches
- Width: 12-1/8 inches
- Depth: 8-1/2 inches
- Required to use with Zinc Swingarm Frame Oil Tank Mount Bracket
