Harley Knucklehead Eclipse Front Hub Nickel Plated - V-Twin 45-0453
SKU 45-0453
$329.99
3299 ENTRIES 🎟️
$329.99 - $329.99
$329.99
3299 ENTRIES 🎟️
Nickel plated eclipse front hub has 36 holes and is retrofitted with 2 sealed ball bearings and 2 cone spacers to give the hub the correct width. Hub is retro fitted with sealed ball bearings inner spacer tubes and two collars which act as a cone. The center tube is installed between the 2 bearings. Spacers included. *NOTE: Includes 3/8 inch axle with 2 hex nuts and 2 flat washers. Fits 1910-1915 Harley Knucklehead models.
  • Hub End to End: 3-1/2 inches
  • Suggested to use with 3/8inch Front Axle.
1910-1915 F
