Harley Shovelhead Eastern Engine Pinion Shaft - Eastern A-24006-73 - OEM 24006-73
by Eastern
SKU 10-0403
$119.99
$119.99
$119.99
1199 ENTRIES 🎟️
$119.99
$119.99
$119.99
1199 ENTRIES 🎟️
Precision ground for correct fitment. *NOTE: Must order key oil pump gear key pinion gear and key sprocket shaft separately. Fits 1973-1980 Harley Shovelhead models.
Eastern #: A-24006-73 · OEM #: 24006-73
- Suggested to use with Motor Sprocket Shaft Key.
- Suggested to use with Pinion Gear Shaft Key.
- Suggested to use with Oil Pump Gear Key.
| 1973-1980 | FL |
| 1973-1980 | FX |
